#298814 - 30/05/2007 00:53 Player goes through long "Checking Diskc Integrity" every sync.
FieroSTi
The title pretty much explains it...my player does the lengthy "Checking Disc Integrity" scan every time I sync now. Any particular reason why? Is it bad, something I should look into finding the source of?
#298815 - 30/05/2007 11:31 Re: Player goes through long "Checking Diskc Integrity" every sync. [Re: FieroSTi]
#298816 - 31/05/2007 19:08 Re: Player goes through long "Checking Diskc Integrity" every sync. [Re: wfaulk]
FieroSTi
Sweet...well, it's a brand new drive; so I'm 98% sure it's not that. I'll have to go through everything else though. It still functions as normal, it just goes through the disc check every sync. It's an odd check, though; because it takes about 5 minutes, and I've got a 120GB drive. Ideally, for the full check, it should take somewhere in the neighborhood of an hour. I don't have intermittent HDD problems though, so I doubt it's an IDE cable, and the solder joints on the header look sufficient. Maybe I'll figure it out.
#298817 - 31/05/2007 20:25 Re: Player goes through long "Checking Diskc Integrity" every sync. [Re: FieroSTi]
Read the whole FAQ, specifically the last link.
